Old Sep 3, 2014 | 10:47 AM
cojoman's Avatar
cojoman
Default Pulse module NOT sending signal
Hey guys,
So i decided to trace my wiring with the wiring diagram to see how power is distributed after i turn the switch. I wasn't getting signal from the clutch interlock but i got that figured out. The problem i am having now is that i am not getting any power from the pulse module to the RCM box to fire the starter. Now am getting signal from the ignition switch and the clutch with all the necessary grounds.
Did anyone have the same issue previously? I am charging up the battery now thinking maybe it was not getting the exact 12volts. Does the ignition switch have any fuses i should be worried about?
Let me know what you think.
