Old Sep 3, 2014 | 04:27 PM
onehundred80
Default Re: Pulse module NOT sending signal
Originally Posted by cojoman
Hey guys,
So i decided to trace my wiring with the wiring diagram to see how power is distributed after i turn the switch. I wasn't getting signal from the clutch interlock but i got that figured out. The problem i am having now is that i am not getting any power from the pulse module to the RCM box to fire the starter. Now am getting signal from the ignition switch and the clutch with all the necessary grounds.
Did anyone have the same issue previously? I am charging up the battery now thinking maybe it was not getting the exact 12volts. Does the ignition switch have any fuses i should be worried about?
Let me know what you think.
I cannot see where the RCM comes into the picture here.
The clutch interlock feeds power to the pulse module and that feeds low amperage power to the starter solenoid.
The starter motor gets its power directly from the battery.
I could be wrong but that is what the wiring diagram shows.
