onehundred80
I cannot see where the RCM comes into the picture here.
The clutch interlock feeds power to the pulse module and that feeds low amperage power to the starter solenoid.
The starter motor gets its power directly from the battery.
I could be wrong but that is what the wiring diagram shows.
Thanks for the reply.
You are right, the wire goes to the starter solenoid. Do you know any reason why am not getting this power to the solenoid? Everything else is working fine except this. This is the reason why the starter is not engaging.
Thank you sir.
