Old Sep 3, 2014 | 11:18 PM
Padgett's Avatar
Padgett
Default Re: Engine swap help!!!!
If I were doing a swap, it would be a current (2010+) Chysler Pentastar DOHC 4-valve 3.6 HP V6 with 290-305 hp NA and bolts to either the 5 speed automagic or the 6 speed manual (in current Wranglers). Might take some tweaking since is a 60 degree V6.
If must have a 90 degree the previous SOHC 3.7 V6 was a 90 degree design like the 3.2. & also uses the same trannys but lower revving and lower peak (215) hp.
Just some domestic thoughts.
