Old Sep 10, 2014 | 11:49 AM
  #234 (permalink)
RED DOG's Avatar
RED DOG
Default Re: Ground Control kits are ready!!!
Sorry if these are stupid questions but I'm not experienced will all the suspension terminology or with working on suspension components . . .
So regarding the anticipated Ground Control kits, they are noted as follows:
Ground Control Crossfire/SLK R170 Suspension Package.
Coilover Conversion Kit $599.00
Coilover Conversion Kit w/ Koni Sport Dampers $1299.00
Coilover Conversion Kit w/ Koni Race Dampers $1499.00
The Coilover Conversion Kit $599.00 This kit provides four "coil over" shocks that replace the OEM shocks. The new shocks have a coil spring mounted at the top, right? These "coil overs" are intended to function with the original OEM coil springs remaining installed, right?
then on these kits:
"Sport Dampers" or "Race Dampers" . . . "Dampers" means coil springs, right?
So with these kits you also get new coil springs that replace the OEM springs, right? The Race Dampers (or springs) are stiffer than the Sport Dampers (or springs). Race dampers (according to Les) are 1200 lb front and 900 lb rear and Sport spring ratings are somewhat less but the actual spring ratings have not yet been announced, right?
And from the photos posted it also looks like these full kits include adjustable rear camber arms . . . is that right?
Thanking the suspension experts for responding and clarifying these things for me . . .
