Old Sep 12, 2014 | 10:24 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: New to the forum-"04 Crossfire" ac problems!!
Originally Posted by hardknocks6936
by the way i do have a bad blower resistor motor but i dont think that should affect anything? i just deal with it, it ddoes blow air out so it is not that important to me right now to fix the blower resistor.....i just hope it is not affecting my ac problem.
Invest $60 in an AC manifold pressure device from Harbor Freight and check your Hi side and Lo side pressures. If your Lo side, charge port is too high, you will push warm air. It is easy to overcharge the system. The Lo should read 130 or a little below if I remember correctly. If you have a %20 off coupon it will come to under $50. I had this problem, bought this, fixed it and now works fine. It's human nature to complicate simple things.
