Old Sep 14, 2014 | 10:51 AM
onehundred80
Default Re: Questions about interior lights
Originally Posted by Mrmiata
Riddle me this.. switch in the "automatic mode" for the dome lights.. lights stay on. They never time out.. as in normally when door is left open after a while they still time out - or when car is started. Put the roadsters (problem car) BCM in my coupe.. works fine. So are we off to check the Security pump module time? If a door switch is bad .. would it prevent the module from eventually timing out?
Lighted door sills await your resolution..
I think if a door switch is 'bad' meaning it never gets to the door closed position then the lights should time out just as they do if you leave a door open.
