Re: Ground Control kit reviews
Les,
If the anti-sway bar is disconnected with the car on the ground does the bar move? There should be no load on the bar when it is just sitting there. Shortening or lengthening the sway bar end links should have no effect on handling, they are only adjustable for clearance issues....i.e. if you lower or raise the car. You should be able to disconnect the bar without it moving...in other words it should not be loaded.
