Old Sep 14, 2014 | 07:39 PM
shatteredhourglass's Avatar
shatteredhourglass
Default Re: 74mm throttle body problems
I had a problem where I damaged the O-ring as I was installing the new TB (found this out later.) Since there was an air leak after the TB in the intake path, the engine would idle high. Removed the TB and found the issue with non-seated o-ring. Re-installed, all worked great!
