Re: Engine Not Cranking Over...
Ok thanks. Could you tell me what the minimum voltage should be when the car is not running and the same when running?
at the moment thee is 11.5 volts with it not starting.
I had this problem once before because an internal light was left on and it totally drained my battery. After charging up over night it was fine.
