Old Sep 28, 2014 | 01:22 PM
FUBU's Avatar
FUBU
Default Re: Supercharger oil leak
Probably the seal gone in the bearing, I have no pictures of that area though except this one I got from someone on the forum.
If it is the seal on the bearing then the bearing could be replaced, if it is a separate seal then you can replace the seal. If it is a bearing with two seals, one each side, then you could in a pinch reverse the bearing and hope the seal on the other side is OK.
180, could you elaborate a bit on this?
Could it be the pulley itself?What seal? I am a bit lost here. Any help would be awesome.
