Old Sep 28, 2014 | 10:01 PM
syfi's Avatar
syfi
Default New Upgraded Mobil Jet Oil
A new and much improved Supercharger oil...
Miami, FL September 26, 2014 - Leading aerospace fluids and parts distribution company, Sky Mart, has announced that it is the first to stock the long awaited Mobil Jet Oil 387. The next generation advanced aircraft-type gas turbine lubricant is formulated to provide the best performance characteristics of Standard Type 2 (Jet Oil II) and HTS (Jet Oil 254) oils. Sky Mart is also one of the first in its industry to distribute Mobil's long-awaited new turbine lubricant. Mobil Jet Oil 387 has been tested in laboratory and in high-stress land-based turbine applications under conditions that are even more demanding than normal aircraft service. It is also approved against the new SAE AS5780 High Performance Capability (HPC) standard. This civil specification was developed to meet the growing performance and quality needs that commercial airlines seek, especially with the entrance of new, higher-output and lower consumption engines. Mobil Jet Oil 387 has also been approved against MIL-PRF-23699-HTS.
Mobil Jet Oil 387 is commercialized for use in aircraft gas turbine engines, including turbo-jet, turbo-fan, turbo-prop, and turbo-shaft (helicopter), in commercial and military service. It is suitable for aircraft-type gas turbine engines in industrial and marine applications, and compatible with other synthetic gas turbine lubricants meeting U.S. Military Specification MIL-PRF-23699.
http://exxonmobil.com/aviation/Files..._factsheet.pdf
