SparkieSRT6
Yes, but upgrading the injectors will require scaling them which can be difficult and time consuming for a tuner. If you change to a SL55 pump, change the filter to an unregulated one and add a adjustable fuel pressure regulator.
Ok, thanks! So I'm figuring on an SL55 pump (like
this one) and a Hengst filter (0024772701)
So now I need to figure out pressure regulation.
What sort of fuel pressure do I need to run to get sufficient fuel through the stock injectors?
