Thread: EGR Valve...
Old Oct 8, 2014 | 10:45 PM
Helrazr's Avatar
Helrazr
Default Re: EGR Valve...
No............. The RCM (relay control module) is easily resoldered. MOst issues are broken solder connections where the connector pins solder to the board. SOMETIMES a relay will go bad, but they are cheap online (about $5 each with shipping if you order 5 at a time).
The CPS (crank position sensor) goes bad when hot quite often, the car will start and run until the CPS gets too warm. Easy to change, $45 online.
https://www.germanautosupply.com/sto...sensor-86.html I carried a spare for three years before mine went out - but several of us carry spares - they do go bad quite often.
Sometimes the OTHER CPS (cam position sensor) will fail but it's really kinda rare.
I sincerely appreciate your time. I need to find a local car club. I miss having that security that if anything goes wrong there'll be a dozen or more members offering to help. Reliable help. Again, this is useful knowledge and much appreciated.
