Re: Check engine light back on ??
fastfred
It's my damm air pump again went to a repair shop and the code is for the air pump again and they checked it for free....... D J already repaired my RCM ... ( thank you DJ)....When cold start I can here the air pump turn on for about 10 sec and turn off .... I have reset 4 times and the Check engine light comes back on and I now know it's thowing the air pump code....what's next ? Maybe replace the air pump?? May be it's going on but not working right??
Might be time to just buy a new RCM. I did for mine when I couldnt get it soldered. As long as your air pump works, it is likely the relay. Sounds like it went bad again. One quick way to check is to open up the relay and look for bad solder points on the air pump relay and check and see if that bronze color plate with the lil magnet dot is burnt up. If it is the air pump relay is no good.
