Old Oct 14, 2014 | 08:43 PM
oledoc2u
Default Re: Crossfire runs rough - cold starts
check your connections especially the crankshaft position sensor. Cold starts, rough idle are signs of the cps being bad. If not there, then I would look at the fuel rail pressure as 180 mentioned a fuel problem that does happen from time to time. Fuel pressure has to be there for a good start. If not, there may be your problem.
