Originally Posted by Bill Welch
There don't seem to be any other symptoms. could be the clutch, although at 85 mph in 6th gear from Tampa to Atlanta the clutch really doesn't come into play does it?
It does have a burnt smell.
Actually it might. If the clutch spring is weak, it could be slipping under the load. Although you would be more likely to notice it under hard acceleration in 1st or 2nd. It's also possible you may have something leaking onto the exhaust pipe or header. It's amazing how much bad smell a few drops of oil or grease can make.
