Thread: EGR Valve...
Old Oct 16, 2014 | 12:26 AM
Sweet2002's Avatar
Default Re: EGR Valve...
Originally Posted by Helrazr
I appreciate all the info fellas but no one has said whether or not it's ok to just delete those stupid things. My only concern would be air/fuel mixture. And I'm just about convinced my starting issue is a CPS or RMC issue.
The EGR has no bad effect on the engine. It makes the engine run COOLER by letting in some exhaust gas while,cruising and at idle is some exhaust gas when cruising and at idle. It does NOT operate at WOT. Disabling it will cost you mileage. Don't know about you but my mileage is nothing to,brag about as it is.
Your not starting when warm is something else. I NEVER delete the EGR, I want all the mileage I can get, even from a performance car.
Have your injectors professionally cleaned or try a new set.
