crookedview
There is a Crutchfield guide for this:
http://www.driscocity.com/crutchfield-speakers.pdf
And as far as the subs, you will either have to cut some of the plastic basket to fit the larger magnets, or I used a heat gun to melt the plastic a bit to reshape the basket. I would advise the cutting method over the heat gun.
I have read all the posts and many have pictures, but I haven't found one on the back carpet. I got it all apart, it was pretty much exactly as it appeared.. the to **** plugs unscrew, the large plugs on the top plastic UNscrew too, this I didn't know, i thought they where like most of those where they just pull straight out, so I may have ruined one. Then you have to unscrew those small corner trim in doors. After the top piece is off you just pull the carpet to the side.
Im more concerned with the silver door handles, do they split completely as they are 2 pieces lengthwise? or do they just split on back and open like a C to slip off?
