oledoc2u
I just went back to your old thread and read thru it again as well as your problem here. Do you know for sure you are getting fuel? I would hate to think after all you have done, a simple fuel filter failing would be the problem. Fuel pump and fuel filter are under the rear end. Just for the hell of it, make sure the fuel pump is working and the fuel filter which also serves as a regulator must be working as well. These can cause starting issues as well. Although not as common as the other problems....good luck....
Alright so I fixed the problem I checked the fuel pressure as everyone suggested I had pressure but I had a feeling it was bad gas. So I drained all the gas and changed the fuel filter and it was extremely dirty. Replaced and put new gas in and it runs just fine. Thanks everyone for all the help.
