oledoc2u
If you can get it to run on starter fluid for a moment or two, then it could be the fuel filter, or fuel. I would change the fuel filter. If doesn't make any difference, then I would think electrical.
; ( i hope you get it figured out easy and fast.
One thing about starting fluid (either) though if u use it you have to keep trying till it starts, or it will sit on rings, and the next day you get it started and you will burn up some rings, then have to pull the motor (ask any farmer). I will only use either on a diesel that does not take complex electronics to run, on my gas motors (ford tractor, garden tractor) I use carb cleaner.
