Old Oct 20, 2014 | 11:06 AM
  #102 (permalink)
mobilefitt's Avatar
mobilefitt
Default Re: Adjustable Rear Camber Arms
Got my GC Arms!
I waited and got a set that were Anodized. Shipping took about 3 days. They look great, and it's great that I have them. The tubes look the straight ones I've seen in all the DIY's with @ 150 degree angle right in the middle. If you can get a swedged tube bent without breaking it, you could use one of those. The J bars on this post should work fine, the bend isn't in the middle, but it might even be more appropriate for our typical application. (Limited's dropped 1.5 inches, or SRT's dropped 1-2 inches).
Im thinking that we need to change up the sway bar application for those still hearing contact when using the bent arms from GC. Either use the stock bar and change up the sway bar links with adjustable links to hold the sway bar farther away from the Thrust (camber) Arm.
Or
A bar with angles that allow for more clearance for the 1 inch portion of bar ( 2 spots where they touch) that comes in contact with the camber arm.
