Old Oct 22, 2014 | 07:42 PM
James1549
Default Re: SRT-6 Antifreeze Change Procedure
As soon as you turn the ignition to "Off", the heater solenoids will close and isolate that volume from the outside world. You may have flushed the heater core using this procedure, but draining it while "Off" may be problematic.
Actually the heater solenoids are 'normal open'. They require voltage to shut off the coolant flow.
James
