akmiekis
Hi everyone I just purchased a 2006 6 speed xfire and I am curious what is the best launch rpms to achieve the best takeoffs? And what can I do to my car (performance wise) to get a better 0-60 time?
P.s. it's a base model
Welcome to the forum.
According to the Automotive Magazines that tested them over 10 years ago, they said to take it up to about 2800rpm then let the clutch out. They didn't say side step it, just let the clutch out. That's how they got their best times. Which by the way was 14.7 sec. for a manual, 15.18 sec. for the automatic.
The Crossfire has what some would call a delicate rear end. It can be modified, and beefed up, but stock it won't stand for a great deal of abuse from dumping the clutch.
The differential will withstand more in the automatic cars because the torque converter absorbs much of the torque, even from the SRT's.
0 to 60 times depend on a lot of factors, temp. road surface, tire traction, moisture in the air etc.
But one of the best performance bargains for the NA cars is simply installing a single NeedsWings CAI.
On the Automatic cars it cuts the 1/4 mile times by nearly 1/2 sec. Or you can install 16" wheels off of a SLK. Using 225/50/16's tires can cut times by 3 or 4/10's as well.
I've never come across a 1/4 mile time listed for a 6 speed using just a CAI.
There are other things you can do as well, a tune, bigger intake, bigger injectors, pulleys. H.P. estimates vary widely. But those who claim the largest H.P. increase seem reluctant to take their cars to the track, so nobody knows for sure how much good throwing everything at it will do.
I do know, NOBODY has got into the 13's yet without NOS.
Where in Ohio are you located?
