Old Oct 23, 2014 | 03:26 PM
hpmotors's Avatar
hpmotors
Default Re: Ignition Switch/Lock Assembly Problems
Originally Posted by americanretrodave
If the key is turning easily, it's probably the steering column lock and you don't need to buy anything to fix it, just pry that little cover off and let the pin and spring drop out, end of story.
I like the graphite but on the six speed I was hoping to find a white one, but I just seem to find the deals on graphite. And I suffer, like several on this site, from that desease that if one is good, two are better syndrom. I'm even worst on old corvettes, I have two '57s, one '59, two '62s, one '63 and two '67s and I'm looking at a '60.
Dave
OK - you got me both ways. First, "pry that little cover off and let the pin and spring drop out". I've been reading a number of posts on this subject, and I was convinced you had to pull the lower panel & instrument panel in order to get the lock assembly out so that I could remove the steering wheel lock portion of the thing. Your saying this is a much simpler task? Which little cover do I pry off etc?
Second way is your cars - Eight Vettes - dang, that trumps 7 MX5's. Well, by comparison with your collection I am a real piker - you have to tell my wife about your cars so she can get off my butt about having too many my own-self!
