Re: What did you do to your Crossfire today?
wished you had called me before you built it , it does look good, but you will need to install some 3" pipe inside the blue hose on each side of the rad support it can go inside /not seen or sticking out of the hose. ,at wot after about 50 yards ir will collapse on you
or you could get the HD black hose from Needswings it works. jim
