dragothegreat
Still trying to find the issue. Unable to find the switch at the windscreen. is there a way to disable the beeping? Parked in garage most of the time and have been running top down.
thanks
cb
WOW . . . You've had this problem for more than 2-1/2 years and are just now posting in this thread again?? Welcome back!
I have a complete top framework (minus the hydraulic cylinders and the rubber moldings) so if there are sensors located in the framework I have them. Also I have a top control module so if you diagnose that as being your problem get with me for that part.
To better diagnose the problem we'll have to take this one step at a time and start over from the beginning . . .
When you reach up, turn the D ring and push up the front of the top . . . what happens? Do the windows go down (I know you said they didn't before but I want to start over). Does the light on the top up / down switch blink and does it beep or not beep? Get back with those answers and we'll continue from there. In the meantime . . . STAY AWAY FROM THE STEALERSHIPS! From your original post . . . "they said he needed a $4800 body wiring harness and $1600 in other parts." THAT IS ABSOLUTELY INSANE!
I hope we don't have to wait years to hear back from you . . .
