Old Oct 29, 2014 | 07:55 AM
ala_xfire
Default Re: converting hi-beams into low beams?
Before you start splicing / relaying, consider that the 2 are joined at the hip internally.
There is only one adjustment, if you adjust so that the hi beam is lower ( like the low beam ), then the low beams
will be pointing almost at the ground.
