Old Nov 1, 2014 | 12:00 PM
amx1397
Default Re: High beams problem
# 1 if the sw is bad you may be able to make it work by VERY FAST turn it on and off.
are the parking lights coming on, and try the left side parking and the right side parking ,,yes there are three settings for the parking lights. also you should have a bell inside the car when the lights are turned on (any lights).
if none of that works check the plug on the back of the switch.
did you or someone else install HID lights what u r saying sounds like HID failure, next to on the sid or just near the headlight look for a box about 3X3 that has wires going to the headlight ,if you have that someone has installed HID lights, Please get that crap off your car. jim
