#1 Crossfire Girl
HI, first time posting.
I have a 2005 Crossfire Roadster which I just bought and have found a couple of problems. I will list one here and do another thread for the other.
First, both of my high beams will not turn on and there is no indicator light indicating a problem lit on the dash nor the blue? ( I haven't seen it yet to know) one that indicates the light are on even when they are burnt out. I checked one of the light bulbs and it does work so that doesn't seem to be the problem. I am hopping it is not the multifunctional switch, all the other function work i.e. blinkers, windshield wipers and spray.
Has any one else had this problem and have any suggestions?
Thanks for any help you can offer.
During my test drive of mine I discovered everything except high beams worked. I don't recall if the hi-beam indicator came on but no brights. The dealer replaced the switch on the steering column.
The illumination control module has a 7.5 amp fuse for each high beam. The white/yellow wire supplies power to the multifunction switch and the white wire back at the illumination control module is the feed TO the high beams after the switch.
Do the high beams work with the push to pass function?
