Old Nov 1, 2014 | 04:33 PM
tastegw's Avatar
tastegw
Default Re: Coolant Leak, need some assistance
Be sure it is not the water pump. (common) A leaking or weeping water pump will sometimes allow the coolant to run down the radiator hose looking like a bad or loose hose.
thanks for response, im not sure where the water pump is located or what it looks like, im not very knowledgeable when it comes to car problems and such.
here is am image to look at:
the bottom arrow is pointing to the source of the leak, the diagonal arrow is pointing strait down (even though it does not appear this way in the image, its from an angle) showing the small leakage in my bottom cover whatever that is called.
