Coolant Leak, need some assistance
Nov 1, 2014 | 05:13 PM
permalink
05roadsterguy
Mar 2008
521
snohomish WA.
Re: Coolant Leak, need some assistance
Sooo. The picture is upside down, and you have a leak from the top hose that drips down ( up in the picture) to some surface below. That is clearly a hose leaking at that point. Try remounting it with a trim or replacing it if that doesn't do the trick. It shouldn't be hard to find ( DO NOT GO TO A CHRYSLER DEALRSHIP!!!!!!!!)
Replacing the hose should be easy. The water pump ( which this does not look like at all )is time consuming and a moderate to easy job, BUT if you are not mechanically inclined, Hire an independent mercedes mechanic to replace it for you. Below are some water pump links.
Water Pump Replacement - CrossfireForum.org
Water Pump - Stressed - CrossfireForum.org
water pump torque spec - CrossfireForum.org
Need a new Water Pump? - CrossfireForum.org
05roadsterguy
View Public Profile
Send a private message to 05roadsterguy
Find all posts by 05roadsterguy
