Old Nov 2, 2014 | 01:37 AM
maxime75us's Avatar
maxime75us
Default What must be done on my Xfire!
What I have to do!
The stop light is malfunctioning... NOT the bulb
NOT SURE, I HAVE READ SOME HAVE THE SAME ISSUE
Right Headlight not functioning. HID 7000. MAY HAVE TO REPLACE THE BLACK TRANS BOX
Headlight covers are super foggy!
ANNOYING BUT EASY FIX. HAVE BOUGHT THE 3M CLEANING KIT
Small trunk struts must be replace. YEP.. MUST BE DONE SOON
Small leaks appeared on the small valve cover and oil cap!
OIL CAP IS LEAKING AND I BELIEVE THE RIGHT COVER AS WELL.
I DID FIX THE LEFT ONE YEAR AGO
EASY FIX BUT TO REMOVE THE EXISTING COVER... IT IS SO HARD... IT IS GLUED LIKE HELL... HAVE TO RE-READ THE TRICK TO TAKE IT OFF WITHOUT DAMAGING THE ALUMINIUM...
YOU ARE OF COURSE WELCOME TO HELP ! )))
Max
