Re: High beams problem
I have already replaced all headlight fuses even though they still looked good. I checked one high beam light and it worked when tested, but I didn't check the second since that seemed to rule out the light bulbs. I have high intensity bulbs but the ones called for by manufacturer.
If I try turning on the high beams quickly several times nothing happens. As to a bell I know one chimes if they are left on when car is turned off but don't remember one when turned on, I will check.
With car turned off and side running lights turned on, only the rear lights come on, nothing in the front, this is on both sides.
When I have the low beam headlights on all rear lights work but only headlights come on in front no other running lights. Blinkers work when used and flash when locking or unlocking the car.
