Old Nov 5, 2014 | 08:42 PM
James1549
Default Re: Crack got to me!
Originally Posted by oledoc2u
age just reflects the miles of pounding down the road.... We have trucks with 20-25 yr old aluminum bud wheels still rolling.... what can wear is the bead lip...causing a slow leak......common high mileage wheels
It is generally corrosion causing leaks around the bead from my experience. When ever I clean off corrosion from rim beads, I always spray clear coat back on the area. It helps seal the alloy to slow down the corrosion process to occur again, but it will. Also on my personal rims, I try to mount tires without the soapy solution when possible. And if I have to use the soap/lube, I wipe clean as much of the bead area as I can before airing the tires. I tend to think that soap trapped in the bead may speed up the corrosion process...
James
