Old Nov 8, 2014 | 09:59 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: My Crossfire has a rough Idle
Originally Posted by Joel
So i scanned the computer using an OBD2 scanner and found these two codes
P0131 o2 sensor (Bank 1 Side 1)
p0137 o2 sensor (Bank 1 Side 2)
Is it possible that it is idling rough due to theses sensors not functioning, thank you again!
It isn't likely that both sensors went at the same time, look for a vacuum or air leak that would cause both sensors to read bad. This isn't my area of expertise, I never had this problem so how about one of the smart guys chiming in?
