Re: Pop out of 1st ?
one mile
I just have picked up this coupe and do not know the history. Is there and linkage to adjust or bushings I need to replace? It has only done it once or twice but do not want to push it. Any input welcome ! Tim
one mile
Click on the link below, the first reply lists all of the TSB's for the Crossfire. Scroll down to almost the end of the listing, about 5th or 6th from the bottom is a TSB (technical Service Bulletin) for issues with the standard transmission in the 2004 models, you should be able to print a copy of this bulletin and go to a Chrysler dealer and see if they will perform the repairs. The only issue, is the age of your car in relation to the date of the TSB. They should be able to pull up the history of your car to determine if the repair had been completed and the date. If it was worked on at a dealer, I would request a copy of the report, don't just take their word for it.
Good Luck....
Dennis
DTMenace
https://www.crossfireforum.org/forum...ata-tsb-s.html
