Old Nov 16, 2014 | 10:54 AM
amx1397
Default Re: Drivetrain "snap" (clunk) noise
Buggin, first thanks for getting the ball rolling on the wave-trac a few years ago with out you we wouls not have a wavetrac. see it here.
https://www.crossfireforum.org/forum...light=wavetrac
now to maybe help my brake pads make the clicking or clunking noise but there is no real problem,, if i back up and just touch the brake peddle i get the clunk, as i go forward i get it again,,but only once in either direction . I have this without the wave-trac and with the wave-trac, i had this with the 307 diff and with the 327 diff . I also have a biger and better Transmission and still have the click,,, i am 90% sure it is the rear brakes
I also had to replace ALL my rear sub frame bushings just over $200, from Chrysler or $500 from Mercedes and if you need them order one per part number as 2 (TWO) come in the box ,,2 front and 2 rear.
On the ground have a person on both sides looking at the rear tires see if the tire moves back and forth as you hold the brake and at about 100 rpm go back and forth in dr and rev. jim
