Old Nov 17, 2014 | 06:01 PM
ala_xfire
Default Re: Messed up electrical system
Originally Posted by Bill F
Get a new battery. conseguir una nueva baterķa
^^ Agree, that's the easiest and most common first step.
After the new battery is installed, monitor the voltage :
@ 12.1 volts with engine off
@ 13.8 - 14.2 volts with engine running.
You can buy an inexpensive digital voltmeter that plugs in the cigarette lighter for $5 or so at most parts stores.
If you are seeing higher voltage, suspect the alternator/voltage regulator.
