Old Nov 17, 2014 | 08:27 PM
xfireon20z's Avatar
xfireon20z
Default Re: DashDAQ XL Datalogging Unit 4 Sale!
Originally Posted by Timesnow
New crank here.
What good is it with out the data card, is that how it knows its talking to a XF? How much is an XF SD? What about the Zietronix whats that do and do I need a special sensor to plug it into the XF?
Be patient boys.
rick it plugs into your OBD2 car computer so your directly wired into the card the SD card is just a sandisk for memory if you want to save different setting or stats for a later viewing, you can buy one for $10...as for the zietronix most people team it with the dashdaq and it allows your to calibrate the map and monitors many different functions example air fuel, throttle position, fuel reg, etc. you will need to run a new o2 sensor if your running there air fuel combo...
