ala_xfire
Most likely the voltage regulator is gone on the alternator.
Do the test James mentioned, if you need a voltage regulator, it is probably best at your mileage
to replace the entire alternator.
Make sure you get the correct unit, Valeo or Bosch.
Thank you just had alternator tested it's bad so it's coming off for a new one thank you again for advice
