Re: Great progress in car but having throttle position problem
Ah.. It just got programmed. Everything shows that the security is fine but the code is about throttle position. The car had fuel sitting in it for at least 2 years. I cleaned out the fuel and bought a new fuel pump. The fuel pressure is also great.
Can i see security error code?
Does your throttle motor open and close when you press the throttle(with key turned to the start position)?
