Re: Eibach springs rear clunking noise
check the rear sway links. Make sure they are still both connected and that neither are broken. The stock link is plastic and the sprung weight can stress the stock links. I had the same problem and found that the nut had come off my sway link. I jacked up the rear tire until it lined up, found the nut off the old links I had replaced and locked it back down.
good luck
