Trenzman
Thanks for the reply. Just so we are on the same page a 18x8.5 would fit the front, what size tire would you recommend on that wheel on the front and there is not rubbing even when sharp turing? A 20x9.5 @ +35mm offset would fit the rear with the 10-15mm spacer, what size tire would you recommend on that rim 275/30? 285/30? and no rubbing of course? Lastly the stock center bore size is 66.5mm correct? these wheels I want to get are 66.6mm I don't think that 0.1mm difference will do any harm. thanks again
