bby412
Thanks for the reply. Just so we are on the same page a 18x8.5 would fit the front, what size tire would you recommend on that wheel on the front and there is not rubbing even when sharp turing? A 20x9.5 @ +35mm offset would fit the rear with the 10-15mm spacer, what size tire would you recommend on that rim 275/30? 285/30? and no rubbing of course? Lastly the stock center bore size is 66.5mm correct? these wheels I want to get are 66.6mm I don't think that 0.1mm difference will do any harm. thanks again
275 on the rear will work 30 or 35, you will need hubcentric rings for the front, the spacers in the rear are hubcentric and they fit perfectly. Without the rings you will never get it centered just right. It will give you the out of balance feel.
