Re: TPMS Sensors
My Crossfire garage door opener control, as well as a spare (part) I tested, worked fine with my vintage 1992 year garage door openers in 2009. When I installed two new garage door openers in 2012 they would not work with the in car opener control or the spare. After many attempts to get the controls to work with the new garage openers, I researched the problem on the forum, and found posts indicated they would not work with rolling codes, so I left it at that. It may be that they work with some manufacturer rolling codes/systems, and not others. There are others on the forum that could not get their Crossfire garage door openers to work with their garage door openers.
I didn't mean to mislead anyone about the functionality of the garage opener control. The point was if you are not using (or cannot use it) the garage door opener control it's easy to unplug it, rather than looking up and removing the correct wire from the plug to get rid of the TPMS light.
