Old Dec 9, 2014 | 10:29 PM
bby412's Avatar
bby412
Default Re: Wheel Size options?
Originally Posted by Trenzman
275 on the rear will work 30 or 35, you will need hubcentric rings for the front, the spacers in the rear are hubcentric and they fit perfectly. Without the rings you will never get it centered just right. It will give you the out of balance feel.
Ok I know I sound like a broken record but I want to very sure before I go any further and realize I can't return the wheels or tires. My 05' limited coupe all stock brakes, rotors, you name it. The fronts will have the 18x8.5 with a 235/40/18 tire, hub centric rings to reduce the vibrations and no spacer needed because the offset is +35mm (same as OEM). For the rear, 19x9.5 with a 275/30/19 or 275/35/19 tire what would you suggest 30 vs. 35 and a 10-15mm spacer to help with the offset because these wheels are +35mm while stock is +22mm. How does that sound, everything look good. thanks for the help
