Old Dec 11, 2014 | 10:55 AM
nickwe21's Avatar
nickwe21
Default Re: Replace tan trunk panel (driver side)
Originally Posted by JEFASOLD
You correct that before you send them, as for the panel, yes there are clips and plastic pins. Go slowly, make sure things line up as you start at the back end and push the panel into place. If the pins don't line up you will crush the pins, I keep a small bag of extra pins around, just in case. It is easier than it looks.
Thanks for your tips Jeff. Would you start by lining up and attaching the pins?
If I had to get some replacement pins where do I go? Does Autozone carry those and what am I asking for?
PS The pictures are perfectly fine on my computer but every time I attach them they turn upsdie down on the forum. Not sure if it has to do with my picture format or my Operating system?
