Old Dec 11, 2014 | 11:47 PM
JEFASOLD's Avatar
JEFASOLD
Default Re: More Ponies... N/A Thread.
There isn't much that can be done, certainly nothing that won't cost an arm and leg. However, if you have the means, check the web for some German made cams. A little more lift and duration might add enough ponies to make you happy but it will be at the expense of decreased gas mileage. It should be noted that this little engine 195 cu in is one of the most efficient engines MB ever built
