Old Dec 14, 2014 | 07:36 AM
RED DOG's Avatar
RED DOG
Default Re: Transmission Control Modual Stuck
One other thing I forgot to mention in our PM communications . . . check the transmission fluid level. Low fluid level will also cause the transmission to go into limp mode throwing that code! It is common for these transmissions to develop a leak at the transmission connector as the OEM O ring goes bad. ALL the original O rings will eventually deteriorate and start develop a transmission fluid leak there.
